Machine Vision
IMAQ Extract Curves VS IMAQ Extract Contour
 What is the best method(IMAQ Extract Curves / IMAQ Extract Contour) to use to extract a closed contour/curve for the above image?
The right image is drawn by hand to illustrate what I want.
What is the application difference for these two methods?
(3,854 Views)
before to do you need to improve your image adage by some function like filters and contrast after that I think the magic Wang is good method for your aim
(3,776 Views)
Accepted by topic author tomsze
also contour search for just close curves
you can use imaq curve for find close curve by setting but I think imaq contour is better for this one
(3,775 Views)
Thanks, Magic wand is also not a bad idea although it cannot do subpixel accuracy.
(3,740 Views)
IMAQ Extract Curves 是找所有的曲线,并输出出来。IMAQ Extract Contour一次只能输出一条线,并且有方向等设置,场景不一样,用法不一样
(3,404 Views)
