Machine Vision
IMAQ Extract Texture Feature collapse
There is a 16-bit grayscale image to be processed and I try to set the "Level" in "Co-occurrence Options" to 65536, but it is so large(the co-occurrence matrix is 65536*65536) that the program crashes as soon as it runs. How can I solve this problem?
(2,554 Views)
What is the memory useage of your program before it crashes? Have you tried increasing the max amount of memory that it can use?
(2,458 Views)
