Machine Vision
IMAQ Match Color Pattern
It should work with avi too. Try the pattern amtching in vision assistant if you really get a match first from the frames of avi.
Message 11 of 12
(1,894 Views)
Are you doing any compression when creating the AVI file?  I'd double check this, too.
Also, if you extract the images, save them to file, and then perform the color pattern matching on them, do you see the same performance?
Marti C
NI Medical
Message 12 of 12
(1,888 Views)
