Machine Vision
IMAQ PCI-1407 Frame Averaging
Is there a slick way to grab (x) sucessive frames and then average them together to output one mean image? (without the use of the Vision tool kit)
(4,040 Views)
Have a look at
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3E83156A4E034080020E74861&p_node=DZ52000&p_submitted=N&p_rank=&p_answer=&p_source=External
I think that should help ...
Have a nice day,
Michael
(4,038 Views)
Thank you... but unfortunately I don't have access to some of the VI's within that solution. I assume they're part of the add-on Vision tool kit.
(4,038 Views)
On a quick galnce the only vi part of the vision toolkit was Windraw. You can use the "imaq without vision display" example, http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3DABC56A4E034080020E74861&p_node=DZ52505&p_submitted=N&p_rank=&p_answer=&p_source=External
to workaround that.
(4,039 Views)
This link seems to be broken... Anyone know what it was pointing to?
Thanks.
(3,932 Views)
