Machine Vision
IMAQ PCI 1422 error in image grabbing
I have a Kodak ES 1.0 camera and 2 IMAQ PCI 1422 card with NI PCI 6602 card. I use software IMAQ version 2.2.
MAX recognizes the presence of the timer card as well as IMAQ card and the diagnostics tests pass in the IMAQ software. But I can't grab a frame through IMAQ software. It says the following error:
<IMG_ERR_PAR1>
<IMG_ERR_SERIAL_TIMO> serial transmit/receive time out. Time out reading from the camera. 7bytes received. Expected:\r\n command was: MDE CS\r
Not able to fix the error.Where could be the problem?
Is there a priority order in fixing the PCI 6602 and IMAQ 1422 to the PCI slots i.e Always 6602 in the 1st PCI slot and IMAQ in the next PCI slots.
Looking for ur solution!!!
Thanks in advance.
-Suriya
Message 1 of 1
(3,406 Views)
