Machine Vision
IMAQ Particle Filter not working
IMAQ Particle Filter not working on the big images(1300x1030) with "salt and paper" noise
(3,298 Views)
I believe that IMAQ Particle Filter has a limit of 32767 blobs (16 bits). Your image obviously contains more than this number. Exceeding this limit used to crash LabVIEW back when using IMAQ Vision 6. I have not tested it in version 7 yet. I'd be interested to know if it's been fixed (at least to the point of not crashing LV). In any case, you are better off using a median filter to filter out salt and pepper noise. You may want to do this on the grayscale image before you get to the thresholded image.
Ken Pietrzak
DCI
www.displaycheck.com
(3,280 Views)
