Machine Vision
IMAQ ROI point tool
I need to have two different ROI points (from the point tool) in a single IMAQ image.
Those two points are correlated to an XY motion system to obtain the respective position of each ROI point.
I believe that the easiest way to do that is to obtain the ROI point and then create my own overlays (building cross-hairs) for each of those points.
Using the ROI tools in an IMAQ image, I need to get the coordinates of the the user "click" when a point is placed.
Is there a way to determine if a mouse click has occurred in an image (I know it can be done in a picture).
If not, can someone please tell me the easiest way to determine if an ROI has been selected and to get the coordinates of the point?
(3,785 Views)
Is this what you are searching for ?
Best regards, Guenter
(3,782 Views)
Nothing is showing up in your post.
I have found the way to work around it, but I would prefer if I could get two ROIs in one image and set the display for a point.
(3,779 Views)
Sorry, I apologize for pasting a local link to the post. Therefore no screenshot appeares.
Now I attached the according screenshot: Create an event that handles the MouseUp event on the image. If the selected tool is the Point -> Take the property "Last Mouse Position".
(3,775 Views)
