Machine Vision
Showing results forĀ
Search instead forĀ
Did you mean:Ā
IMAQ Segmentation VI
when using  IMAQ Segmentation VI,there is an error saying invalid image type.
and program is in the following:
7BB[WB7K3[YSZ@LH0@O{875.jpgwhat's the matter?i really appriciate your help.
Message 1 of 10
(6,514 Views)
Dont you think the wiring can be better? Instead of attaching a part of your vi can you attach your vi instead or the entire screen shot after cleaning? What is the image type that you are trying to segment? Have you thresholded the image? Have you defined individual buffers(IMAQ create) for the each of the transformation/conversion (RGB,GReyscale,Binary)?
Message 2 of 10
(6,506 Views)
sorry,this is a starting project,i'll deal with the wiring later.the shot screen has a problem,the image type of image7 is graysclale,but even that the same error is existing.i have threshholded the image and i have defined the buffers.
Message 3 of 10
(6,498 Views)
In the "image 7" you have defined the image type as a RGB change it to grescale 8. The error should go off.
Message 4 of 10
(6,496 Views)
i changed both the segmetion VI and the label VI's image type to GRAYSCALE U8,then the program went right but  the result is not what i want.i will check it .tk u very much muks.
Message 5 of 10
(6,494 Views)
You should apply a proper threshold? I willsuggest you first try the segmentation with vision assistant to get an idea.Generate a vi from vi assistant.
Message 6 of 10
(6,492 Views)
thk you,i will try.
Message 7 of 10
(6,477 Views)
Accepted by topic author tuming
Solved?
Message 8 of 10
(6,412 Views)
Any update?
Message 9 of 10
(6,354 Views)
sorry.too late to reply.it was solved,thank you.
Message 10 of 10
(6,340 Views)
