Machine Vision
IMAQ VISION FOR USB CAMERAS
I installed the software "IMAQ Vision for USB cameras" with Vision Assistant 7.1. In the doc, NI mentioned that it should work for every webcam which complies with DirectShow. I tried with the Logitech QuickCam Pro 4000. Although, Vision Assistant "sees" the webcam, I get always the same error : "The settings for this camera are not valid". I tried with several webcams, and got always the same message. This is surprising, since most cameras are DirectShow compatible. Does anybody succeed in using this software ?
Yves
Message 1 of 11
(6,866 Views)
Hi
I am using exactly that model with vision 7.1 and it runs fine.
I will try using vision assistant and will post back.
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
Message 2 of 11
(6,822 Views)
Hi..
I'm using creative live pro and it works well in labview and vision assistant. Creative webcam vista works too..
Message 3 of 11
(6,821 Views)
Hi
I've the same problem and I'm using a logitech quickcam. Can't anyone help us ?
Message 4 of 11
(6,723 Views)
Hi all
I have no problems using a Logitech Qc pro 4000 whit vision 7.1 or vision assistant 7.1
Install vision, then qc driver V8.41 and IMAQ for USB.
It runs fine in Windows XP pro SP1.
Cheers
Alipio
Message 5 of 11
(6,695 Views)
so I'm using Windows XP SP2, with qc driver 8.41 and IMAQ for USB.
I cant use my webcam on Vision 7.1, the message settings not valid appears everytime.
If it is the camera settings, can anyone give me the correct settings to use it on vision ?
Message 6 of 11
(6,582 Views)
i've the same problem with XP SP2, QC Driver 8.41, IMAQ USB, and using a Quickam Web or Quickam Messenger...
What can we do?
Message 7 of 11
(6,495 Views)
What can we do?
Message 8 of 11
(6,490 Views)
Has anybody already had a fix for this problem. Seems like it is raised by SP2. I suffer the same issues with my creative webcam.
Ton
My LabVIEW Ideas
Message 9 of 11
(5,885 Views)
Hello friends,
First sorry for my bad English
I had problem the same, and my operational system was windows xp professional SP2 português Brazil.
I only obtained to decide the problem changing the operational system for windows pro coorporation english
I wait to have helped!
Ricardo Santos
Message 10 of 11
(5,699 Views)
