Machine Vision
IMAQ Vision library
Hi, I am using Labview vision acqusition 8.0 with IMAQ vision but I think my IMAQ library insufficient since in my application I need;
IMAQ Release List.vi
IMAQ Stop.vi
IMAQ Status.vi.
how can I find those to make my application executable?
Your help is very important.
Thanks.
(4,183 Views)
beckology,
The VIs associated with the IMAQ driver can be either installed on your target machine by installing Vision Acquisition Software 8.0 or you can create an installer for your application to include this driver. In LabVIEW's Application Builder, right-click Build Specifications > New > Installer > Additional Installers and be sure to select NI-IMAQ x.x.
Does this help?
--Michelle
(4,165 Views)
Thank you for your considiration.
It is working now.
Best regards.
(4,136 Views)
beckology,
You are very welcome! Good luck with the rest of your application.
--Michelle
(4,105 Views)
