Machine Vision
IMAQ WindClose.vi
I've installed LabView 7.0, and in the toolbox in vision i can't find the IMAQ WindClose.vi and IMAQ WindDraw.vi, i really need with urgent, please i need to find this vi's
(3,397 Views)
You installed Imaq VISION and you can't find these two viS???
Did you find them since then ?
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(3,397 Views)
Hello Fito.
These VIs will be installed only when you have the IMAQ Vision Development Module installed (not just with NI-IMAQ). If they are not present in your palettes, then I would verify the installation and/or re-install the IMAQ Vision software. When you install it, you must make sure that support for the LabVIEW version you are using is checked.
Colin C.
Applications Engineering
Colin Christofferson
Community Web Marketing
Blog
(3,397 Views)
