Machine Vision
IMAQ Write File 2 - Black Image
Hi
I've got quite a simple microscope application to display an image from a GigE camera, then when the user clicks a button (read by LV and then reset), it saves it to a BMP.
This seems to work ok, 99% of the time. Occasionally the image saved is completely black? Would appreciate it if anyone could have a look at my code and let me know If I'm doing anything wrong! Thought it maybe some sort of pallete/synching issue?
(4,046 Views)
I do not see an obvious issue with your code.  Can you post the VI?
(4,018 Views)
Hi
Many thanks for checking my setup. I've since found that the cause is probably user, rather than software related! I think the operators, when running through batches, are removing the item they are imaging from the FOV before software has time to take the image! (it sometimes takes a while over the network). Thanks again.
(4,002 Views)
