Machine Vision
IMAQ absolute difference issue
Hi all,
Have a look a the attached VI (LV 8.20).
Here is what it does :
    1. creates 3 8-bit grayscale images (A, B, sous)
    2. sets images sites (same size for the 3)
    3. fill each image with a different gray level (the 3 levels are setable)
    4. perform an IMAQ absolute difference "abs(A - B) = sous"
With the default values I set ( 200 for image A, 50 for image B, and 0 for image sous) at the end the result is, as I expect :
    A is still at 200
    B is still at 50
    sous is at 150
Now if I set :                                                 I expect :                           instead I get :
    A any level between 0 and 255                  A still at anything                  A at anything
    B level = 0                                                  B still at 0                             B at anything
    sous level = 0                                             sous at anything                  sous at anything
Is there a good reason for this Smiley Surprised ?
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,918 Views)
The problem in your VI is the name of your images.
Indeed, when you take A=255 B=0 and sous=0, the images B and sous have the same name and consequently you have the following result :B=sous=0
Take care to give different names to your images as attached in this post.
Sincerly,
Olivier
(3,896 Views)
wooops... indeed Smiley Surprised
thanks for your help... sometimes I get so focus on the process that I completely miss everything... Smiley Mad
Epictetus
Antoine Chalons
(3,890 Views)
