Machine Vision
IMAQ can't find nivissvc.*
I'm trying to grab some image data from an imagingsource dmk 41bf02.h. Their software works but when I try to open up IMAQ Create from within basics.llb from the LabVIEW 2010\vi.lib\vision folder, I get an error:
IMAQ Create - Block Diagram Errors - Call Library Function Node: Library not found or failed to load. After I 'show error' and then do 'configure' on the erroring part, the library name or path says "nivissvc.*". If I click the folder to browse to it, LabVIEW cannot find the file within c:\windows\system32. If I copy the nivisscv.dll from \system32 to the desktop and try again, LabVIEW says that "the library selected is not valid for the current platform. For example, you are running 32-bit LabVIEW and the library might be a 64-bit library."
I am running Windows 7 Professional 64-bit, but LabView 2010 Fall 32-bit. LV2010 was 64-bit and we uninstalled the 64-bit version in favor of the 32-bit version.
So, did I miss something? Is there something I need to do?
Thanks in advance.
Message 1 of 1
(4,369 Views)
