Machine Vision
IMAQ dll giving strange results
when i try to use the imaq.dll file found in System32 it gives me strange results when using it. Such as imgInterfaceOpen(char[], INTERFACE_ID) says that is really wants imgInterfaceOpen(NumericalArray, INTERFACE_ID). any ideas on how to fix this
I am trying to use MATLAB to access this dll and i MUST use DLLS. Since the types dont match MATLAB willnot run the code.
I have vision 8.5.1 installed.
Thanks.
(3,303 Views)
Hi Chico,
I would take a look at the NI-IMAQ Function Reference Help which can be found by going to Start»Programs»National Instruments»Vision»Documentation»NI-IMAQ.  You can look up the imgInterfaceOpen function here and see all of the input parameters and such.  This would be the best place to start.
Wes Pierce
Principal Engineer
Pierce Controls
(3,284 Views)
