Machine Vision
IMAQ imgPlotDC2
Daniel, I tried creating my own black and white striped image, and I did get the incorrect behavior Nate was experiencing. In addition, I was able to recreate the behavior with a 12-bit camera.
Eric, thanks for confirming this is a bug. I move on to trying out the built-in display through VisualStudio and GDI+.
Nate, I was looking at the Format16bppGrayScale option when trying to build this workaround and I got the same error. Most of what I could find suggests the member isn't supported by Microsoft and was implemented incompletely for display.
Ravi A.
National Instruments | Applications Engineer
Message 21 of 23
(880 Views)
Hi Nate,
I have a small snippet of code that should allow you to work around the issue for the time being. Note that this is C code so you might have to either compile it into a native DLL or re-work it using native C#/PInvoke calls. Presumably if you were already calling the IMAQ C functions from C# then you'll be able to figure how to emulate what this C code is doing Smiley Wink
Int32 imgPlotDC2_workaround(void* hdc, void* buffer, uInt32 leftOffset, uInt32 topOffset, uInt32 xsize, uInt32 ysize, uInt32 xpos, uInt32 ypos, uInt32 flags) {
    static HMODULE library = NULL;
    typedef int (__stdcall *Gen_PlotImageToDCFunc)(void*, const void*, uInt32, uInt32, uInt32, uInt32, uInt32, uInt32,  uInt32);
    static Gen_PlotImageToDCFunc func = NULL;
    if(!library) library = LoadLibrary("nivissvc.dll");
    if(!func) func = (Gen_PlotImageToDCFunc)(GetProcAddress(library, "Gen_PlotImageToDC"));
    return  (*func)(hdc, buffer, leftOffset, topOffset, xsize, ysize, xpos, ypos, flags);
 Note that this code is untested and may cease to work in the future as it is using internal interfaces.
Eric
Message 22 of 23
(863 Views)
Hi Eric,
Sorry for the long delay in my response. Yes, the Gen_PlotImageToDC function is working in my 64-bit application. This is an acceptable solution for now. Please keep us informed when imgPlotDC2 is fixed.
Nate
Message 23 of 23
(852 Views)
