Machine Vision
IMAQ match pattern 4
When I use the IMAQ Match Pattern 4 VI,  there had an error like this:
what is wrong with this? How should I do ?
would you help me?
(4,421 Views)
Looks like LabVIEW/Vision bug caused exception in C++ Run-Time.
Can you please post minimal snippet of the code and probably image where this exception can be reproduced?
Is it happened with all images or with particular images?
(4,408 Views)
Thank you for your answer.
And now I have found the reason of the error,it was the camrea had some problems,and it caused the image was not complete.
(4,291 Views)
