11-03-2016 01:45 AM
Hello everyone,
Solved! Go to Solution.
11-03-2016
03:17 AM
- last edited on
07-22-2026
11:34 AM
by
Content Cleaner
-Many parameters are associated with type of matching technique you select: Pyramidal matching and image understanding (low discrepancy sampling).
-You can check with inbuilt examples: LabVIEW\examples\Vision\Pattern Matching\Pattern Matching (All).vi
-Context help and Vision Concepts on Pattern matching gives full idea on what each parameter does and when to use. You can check this thread : https://forums.ni.com/t5/Machine-Vision/How-to-improve-Pattern-Matching-Algorithm/m-p/3359088
