Machine Vision
IMAQ under Win XPx64 with PCIe-1433
I have an IMAQ app written with VS2008 (managed C++, using PInvoke). The 32-bit version works fine. But I want to build a 64-bit version.
I have IMAQ 4.4.0 (March, 2010 release) installed. My framegrabber is a PCIe-1433. I'm running Windows XP Pro x64 on a BOXX Technologies machine.
When I build an x64 version, I get error 0xBFF60150 from imgSetBufferElement (... IMG_BUFF_ADDRESS ...). imgShowError tells me this means "The operation is not supported for 64-bit applications."
Does this error mean I can't make an x64 build with IMAQ under XPx64?
Or does it mean that one of the parameters to imgSetBufferElement (... IMG_BUFF_ADDRESS ...) is incorrect?
Thanks in advance.
(3,342 Views)
Accepted by topic author jhc2
Hi jhc2,
If you look at the signature for imgSetBufferElement you'll see that the value paramater is defined as a uInt32. This would not be compatible with a 64-bit application since the pointer is 64 bits wide. If you take a look at the C examples included with your version of IMAQdx you can see how the replacement function imgSetBufferElement2 should be used as a replacement in new code (imgSetBufferElement should now be listed as "obselete" in the header). The new version replaces the old version of the function and is compatible with both 32-bit and 64-bit code. The syntax and parameters passed should be identical.
Eric
(3,333 Views)
Thanks, Eric. That was the problem.
(3,330 Views)
