Machine Vision
IMAQ
my Labview program makes snap with PCI -1411 and
represent the images on the front panel in the Imaq image control. This front
panel controled at the Client computer (with employment of Labview Web server)
the images appear at the Client computer very slowly, can i make it better?
(3,241 Views)
Dear Olga,
as an Image has much more data to be processed as a normal control or indicator the WebServer is not the applicable method for controlling this imaq application. I prefer using TCP/IP programming to get this amount of data handled. If not you should decrease the size of images before sending them over to the Client PC. This would speed up the application.
Eye-catcher
(3,215 Views)
