Machine Vision
IMAQdx 8 bit grayscale AVI problem
Hello, I am having an issue with a simple vi in which I am trying to save a uncompressed avi file (8 bit greyscale) at 30 fps. I have looked around at various posts and vi's that people have posted but I can't find the reason my program is not working.
The video seems to record fine, however once I open up the .avi in VLC media player the video plays extremely fast as it has only recorded a handful of frames. E.g a 5 sec video at 30fps is outputting 8 frames. Also in the codec information in the media player it thinks the video is a 24bit RGB.
I've attached the vi, please let me know what you think.
(3,595 Views)
ok just think about them
if you have 8 frame with 30fps so you have video with 264 millisecond length so it is almost nothing to see
if you have 5 second video with 30fps so you have to have150 image for this reason
the thing that you can do with 8 image or frame  to make it 5 second video is one of two method bellow
1 use 2 fps to video to have 4 second movie
2 copy every image 18 times and use it in video to have 30 fps video
(3,573 Views)
