Machine Vision
IMAQdx Camera USB shows up in Ni-MAX, not in Examples Imaqdx
I am new to the forum.
Please forgive any mistake.
Versions informations:
Windows 7 64bit
Labview 12.0.1 64 bit
NI Max 5.4
IMAQ 4.7.2
IMAQdx 4.1
I have two USB camera, one from Pixel-link, the other from Veho.
Both drivers are installed. Both camera are recognized by the PC
Both Cameras are seen by NI-MAX as IMAQ-dx devices and I can grab, snap and save an image from NI-MAX
When I open Labview and run any example from the IMAQ-dx library, I always get the error code -2147220969 from the IMAQdx Configure Acquisition.vi.
Thanks for your help
Olivier
(4,637 Views)
Post your script, So that can help you better
Silver_Shaper | CLD
(4,633 Views)
If you are using 64-bit LabVIEW you will need to ensure you have proper 64-bit driver pieces for your DirectShow camera from your camera vendor. If they only have 32-bit pieces then it will only work in 32-bit applications (NI-MAX is 32-bit). Generally both 32-bit and 64-bit pieces should be installed on an x64 system to ensure it works with any application.
Eric
(4,627 Views)
Thanks a lot. I tested it on another PC where I have Labview 32bit and indeed it worked perfectly well.
Now I have installed Labview 32bit together with the Labview 64bit on the first PC.
Shall I also re-install Vision, or can I tell Labview 32bit that it is already installed?
At present the Vision vi's are not found by Labview 32bit.
Olivier
(4,613 Views)
