Machine Vision
IMAQdx Capture using a GIGE camera and LabVIEW
Im pretty sure that it is the Display. I was wondering if there was anything that i can do that will allow it to display at full resolution and full frame rate.
Message 11 of 12
(1,545 Views)
Hi MarcusG!
Since you are able to get the max frame rate in MAX, your connections are working well.  The issue, therefore, is with the software.  In other words, your processor is doing other things in the background and preventing you from acquiring at the max frame rate.
Try using a sequence instead- there is an example in the NI Example Finder called Sequence.vi.  (Appropriate name, huh? J).  The sequence should allow you to acquire at the max frame rate.
Kristen H.
Message 12 of 12
(1,536 Views)
