Machine Vision
IMAQdx Grab2 VI
I have use IMAQdx Grab2 VI to taking image,but when the Buffer Number Out up to a certain number,for example 42301,it will not be increase ,and the the Grab2 VI did not report error,why Buffer Number not increase?
(3,248 Views)
-What camera you are using?
-Do you get images even though buffer number not increasing?
-After exactly what number it doesn't increase?
-Can you post the code which you are having issue with?
uday
(3,210 Views)
If the Buffer Number is not increasing, then your Camera Driver is not taking frames (or something else is seriously wrong).  Post your code if you think that the problem is your LabVIEW Code.  Take your Camera to the Camera Repair Shop if you think the problem is the camera hardware.  Check your wires if you think the problem is that the cable connecting the Camera to the Computer isn't working.
If posting code, please attach VIs, not pictures of the Block Diagram.  It will also be helpful to tell us the camera you are using, and how it interfaces to your computer (USB, TCP/IP, via a special hardware board, etc.).
Bob Schor
(3,177 Views)
