Machine Vision
IMAQdx Installation problems
Using latest Vision Acq 8.2.3.
IMAQdx says its installed under Software section but it does not
show up under Device and Interfaces section for squat.
Multiple re-installs and even tried on other computers.
Running under WINXP with temp license....
I have a PRO/1000 NIC installed on one pc and alternate 100Mps NIC
on other tested machine. No good.
HELP.
(4,178 Views)
I'm a bit confused.  What isn't showing up in your Devices and interfaces?
Do you have a GigE camera installed?
You might want to look here if you are trying to use a GigE camera:
Thanx
AdamB
Message Edited by AdamB on 05-25-2007 07:47 AM
Applications Engineering Team Leader | National Instruments | UK & Ireland
(4,175 Views)
Thankyou for the quick response.
I am using a GigE to Cameralink converter from Pleora (PT1000-CL).
I have a prototype Cameralink camera that we have tested and run on
both the NI-1426 and NI-1430e framegrabber boards.
The IMAQdx tab is not showing up under Devices & Interfaces.
(4,166 Views)
Eric G had said this unit would work with NI.
See:
http://forums.ni.com/ni/board/message?board.id=200&message.id=13150
(4,162 Views)
Should the IMAQdx tab always be under Devices and Interfaces
when a camera is connected or disconnected?
IMAQdx shows up as 3.0.1 under Software tab but never shows
up under the Devices and Interfaces tab on 4 computers I have
installed Vis Acq 8.2.3 on.
Is there a hardware or other software requirement that is keeping
the IMAQdx tab from showing up?
(4,137 Views)
