Machine Vision
IMAQdx Write Attributes.vi
Anyone know where to find this vi?
I need to programmatically set and save camera attributes.
nacree
(3,875 Views)
On the NI-IMAQdx Low-Level palette, nacree.
Regards, Guenter
(3,869 Views)
Hmm,
It's not there on my system, here is a screen shot
(3,857 Views)
Hi there,
You could use the read and write to registers.
Or..... you could go up one level and use the property nodes.  You should be able to find the attributes you need in there.
Hope this helps
AdamB
Message Edited by AdamB on 12-13-2007 09:19 AM
Applications Engineering Team Leader | National Instruments | UK & Ireland
(3,854 Views)
