Machine Vision
IMAQdx initialize unknown error (-1074360311)
I am trying do the example code of a sbRIO Starter Kit 2.0 to follow a tennisball, that is based off of this example  (https://decibel.ni.com/content/docs/DOC-18154). But when the IMAQdx tries to initialize, I get the error -1074360311. I have tried to download some drivers to remedy that but they do not work.
(4,217 Views)
this error is farming error it show that the camera you select to work with it 'support DirectShow interface for connection this interface just work for windows and you have to select one of these camera for work with sbrio
https://www.ni.com/en/support/documentation/supplemental/16/usb3-vision-cameras-and-ni-real-time-tar...
also see this
https://www.ni.com/en/shop/compactrio/what-are-compactrio-controllers/machine-vision-on-compactrio-a...
and this
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KYuSAM&l=en-US
(4,166 Views)
Thanks for the reply, so this project is not possible on the robot and AXIS camera that I have. Then how did it work on the robot example that is in the example?
(4,159 Views)
for this project they use Starter Kit 2.0 Robot
but this product are not available in NI
I suggest to use mini pc or windows base tablet for doing this project with combination of some wireless or Bluetooth tools like Arduino WiFi Shield
see these link I hope they could help you
https://www.arduino.cc/en/Main/ArduinoWiFiShield
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4PhCAI&l=en-US
(4,154 Views)
