Machine Vision
IR tools for Labview IMAQ
Where are the Labview VI's for thermal imaging? They used to be available on NI website, but I cannot get to them anymore. FLIR website doesn't have them either, just a link to NI website which is not working.
(3,488 Views)
Hello Boldorin,
The VIs that you are referring to were created by Flir, and they kept the ownership rights to the VIs and thermal algorithms.
The contacts at National Instruments recommended you contact Flir for the VIs.
- The link of ni.com was removed because Flir wanted to control the usage of the VIs (possible to modify or distribute).
(3,488 Views)
