Machine Vision
IVA match geometric pattern algorithm.vi
Hi!
How can I find "IVA match geometric pattern algorithm.vi", which vision module supports this library?
Please help!
Thanks.
(4,617 Views)
The IVA Match Geometric Pattern Algorithm.vi was generated by NI Vision Assistant.  It is basically a wrapper for IMAQ Setup Match Geometric Pattern and IMAQ Setup Match Geometric Pattern.  These functions (are included with the Vision Development Module, and can be found on the LabVIEW block digram under Functions»Vision and Motion»Machine Vision»Searching and Matching.
Chris Bolin
LabVIEW Partner Program, CLA
(4,589 Views)
Sorry, that's the IMAQ Setup Match Geometric Pattern and the IMAQ Match Geometric Pattern.
Chris Bolin
(4,577 Views)
