Machine Vision
Ideas for video in video
Any tricks to perform video in video
(4,016 Views)
Like a picture inside a picture?  Fairly easy.
For each image, use ImageToImage to insert the smaller image into the larger one.  You may need to resize the image using extract first.  Then display the image and repeat with the next frames.
Bruce
Bruce Ammons
Ammons Engineering
(4,014 Views)
Hi Bruce,
  When i use the imagetoimage  function I get  a blank image. Seems funny. When i tried the copy image function, it shows the copy of the image. Am I doing something too silly?
(3,955 Views)
12222 wrote:
Hi Bruce,
ImageToImage works perfect as Bruce suggested:
Post your VI if you have any troubles.
Andrey.
(3,952 Views)
Hi Bruce,
  Please have a look at this section of the vi. your suggestion works fine for still images. I tried that before. But for real time videos, there's something I don't understand.
regards
(3,915 Views)
Accepted by topic author 12222
What exactly you can't understand?
Be sure that:
- both images are the same type (U8 or I16, etc)
- if both images are 16 bit, then they should have neraby same intensity  (because mapped to 8 bit for display)
- small image is really smaller than bigger one
- small image positioned not outside
- both cameras deliver nearby same frame rate. If not, it will be good idea to organize separate threads.
- check error output
Andrey.
(3,905 Views)
