Machine Vision
Im using a 1408 board
?How can I define a triggered based acquisition
with RTSI0 and RTSI1?
the function imgSessionTriggerConfigure only lets define one trigger source, (RTSI0..4, IMG_EXT_TRIG0..4) and I need start the acquisition with RTSI0 and RTSI1 thank you
(4,065 Views)
Unfortunately, IMAQ does not support triggering on multiple sources. You cannot trigger on both RTSI0 and RTSI1 at the same time. You may try to use external circuitry to AND the signals to feed into 1 RTSI source.
Ken
(4,065 Views)
Ken
(4,065 Views)
