Machine Vision
Image Calibration without template
Hi
I have a camera set to observe an inside of a pipe. Because I know the angle of the camera and where is it situated inside the pipe, I can produce an array of points that correspond to specific pixels. Because camera can move up and down and change the angle, I have to do it dynamically, so I can't load any calibration file, because it is changing on the spot.
So I've managed to create the calibration points and pixel points, but after using them in Learn Perspective Calibration.vi image doesn't change.
What am I doing wrong?
(3,232 Views)
Accepted by topic author siadajpan
Sorry, I'm just stupid. I was missing "Correct Calibrated Image.vi" at the end
(3,172 Views)
