Machine Vision
Image Reference (Control/Indicator)
Any reason for not creating Control/Indicator for the reference of Image datatype.
Even Grouping of Image Reference in a cluster is not possible.
 Any Specific reason for this restriction?
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 1 of 1
(2,395 Views)
