Machine Vision
Image acquisition using webcam/camcorder
Is it possible to use a camcorder/webcam to acquire image at a fixed frame rate &resolution using labview, so that those videos can be processed using the IMAQ.If anyone has an idea about how this can be done,please reply me.
Thanx
Deepak
(3,689 Views)
Deepak,
Yes it is possible to aquire images from a camcorder or a webcam into LabVIEW. However there are a few considerations for each. When using a camcorder, you may want to use one our IMAQ PCI-1411 Boards that support color/monochrome aquisition. If you are connecting from the camera video output, you will need a connector to convert it to a BNC connection at the card. With a NTSC signal you should aquire 30 frames per second, and 25 fps for PAL signal.
When using a webcam, it is most likely a USB input to the computer. USB cameras do not have a standard format, so NI has not come out with a USB driver for acquiring the image data. If you can find a driver from the web cam manufacturer that allows you to get access to the 2-D array of pixels, you can convert th
is to a LV image type and use Vision processing on it. I hope this helps.
Best Regards,
Chris D
NI Applications Engineer
(3,689 Views)
