Machine Vision
Image analysis - dual core advantage?
Hi
Could anyone with a dual core cpu try and run this.
I tried to make some of the analysis in parallel threads and want to see if the computation speed has improved from it!
Please just post a screen shot of the front panel so I can see the computation times.
Remember to type in the path for the U8 image files.
Regards
Simon
(3,747 Views)
Here are my own results.
Naturally im not benefiting from the parallel programming, at the moment my pc is single core.
SYSTEM:
AMD64 3700+
1Gb of PC3200 DDR, DUAL, 400 Mhz
(3,745 Views)
Here is an updated version of the .vi
(3,722 Views)
Here's my try
2x2.13GHz
2Gb RAM DDR2
Thanx
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
(3,541 Views)
