Machine Vision
Image processing after IMAQ USB Snap
Hello
I want to process the image after IMAQ USB Snap.vi acquired,but there is no result.
Can someone help me and give me an simple example ?
Thanks a lot
帖子被skyover在11-22-2007 12:36 AM时编辑过了
(4,420 Views)
Hi skyover
After having a quick look at your block diagram image, it seems to me you haven't wired the image reference from IMAQ Create to the input of the sequence structure. Otherwise, I see nothing really wrong about the code.
Vladimir
View my profile on LinkedIn
(4,415 Views)
I have wired the image reference from IMAQ Create  to the input of the sequence structure,but to the Histograph indicator,I still get nothing
I think somewhere is wrong,please help me have a look
帖子被skyover在11-22-2007 04:12 AM时编辑过了
(4,412 Views)
用Vision Assistant,然后选择create VI
(4,369 Views)
