Machine Vision
Image types in Vision 6.01 verses 7.0
The Image data type in Vision 6.01 is a cluster and is different than the image type in Vision 7.0. Is thre a way to make my newer version of LV work with this older version of Vision?
(3,196 Views)
Mike,
Probably thi link will be helpful for you:
http://forums.ni.com/ni/board/message?board.id=200&message.id=5849#M5849
But I haven't tested Vision 6.x with LabVIEW 7.x
Andrey.
(3,191 Views)
That was perfect. Thank You.
(3,188 Views)
