Machine Vision
Images Not Being Saved as 16-bit
We are using a Basler acA2000-340km camera.  I am able to capture frames in 10-bit and 12-bit pixel bit depth successfully.  However when I try to save those frames to disk they are only being saved in 8-bit format.  I tried using both .tif and .png images.  I am using the imgSessionSaveBufferEx() function to save the image.
I noticed in MAX 10-bit and 12-bit acquired frames are correctly being saved as 16-bit images.  What am I missing here?
Thank you.
(4,377 Views)
I noticed in the camera file used by MAX that the bit depth is being specifically set.  I tried doing the same thing in C++ but when I try setting both the IMG_ATTR_BITSPERPIXEL and IMG_ATTR_PIXDEPTH attributes I am getting an error stating that those attributes can't be set.  Which attribute am I supposed to use for setting the pixel bit depth of acquired frames?
Thanks.
(4,374 Views)
I am saving 16bit images in Png.
Is the image you saving from is 16bit?
Do you want to post code?
Amit,
Amit Shachaf
(4,351 Views)
Hello Amit,
Yes the image was acquired in 10-bit and stored in a 16-bit buffer.  I tried both TIF and PNG formats.  It looks like the problem is that NI needs to be specifically told that the image is 16-bit.  I am hoping that I don't need to create customized camera files just to set the bit depth.  I was hoping I could do it through one of the attributes.
Are you coding in C++?  How are you indicating that you have 16-bit images?
(4,340 Views)
