Machine Vision
ImaqdxSession.Grab frame number
Hi All,
I use the following overloaded method in ImaqdxSession to grab images.
ImaqdxSession.Grab Method (VisionImage, Boolean, UInt32)
I pass in the frame number as the out parameter. Can you please let me know if the frame numbers start from 0 or from 1.
Venkat
(3,454 Views)
Hello Venkat,
The frames should be zero indexed when you use the grab method.
Cheers,
Joel
(3,437 Views)
