Each call to IMAQ Create makes a new buffer or storage location in memory for an image. Noitce that most of the IMAQ Vision processing functions have an input called Image Dst. If Image Dst is wired, then the processing results will be stored in the new buffer you have created with IMAQ Create. If Image Dst is not wired then the results are stored in the buffer used by Image Src, overwriting the original contents. When we pass an image to the Windraw, we are really just passing a reference to the image's location in memory. If you perform multiple operations on one image without creating new image buffers, then the results of intermediate steps will be lost.
Brent R.
