Machine Vision
Inspect defect use of golden template comparison
Hi ,all!
      I want to inspect the defect of LCD. I have read IMAQ Vision for LabVIEW User Manual .PDF.I use the strategy the PDF mantions. Firstly,build the coordinate system from the local to template;secondly,use the find pattern to get the allignment to the golden template comparison.vi. I also read the example of golden template comparison from Find Example (golden template inspection.vi).I use the code from golden template inspection.vi. I can't get the reslut from it.
      I don't konw what is wrong. Can any one help me to handle this . Thank you so much!
      attach is my VI and image.
(3,616 Views)
I dont have 8.6 with me and am still with 8.0 but the images are working fine with pattern matching and golden template matching when i created a similar template.
18333i6ADB862A41929989
(3,607 Views)
