Machine Vision
Insufficient transfer engine resources
I am using Vision Acquisition Software(2011) to acquire images from basler scA640-70fc(firewire) on a Windows XP- 32 bit system. I can grab at upto 30fps. If I switch the mode to acquire 60fps it gives error Insufficient transfer engine resources. How to resolve this problem?
(5,503 Views)
If you have any other Firewire cameras iny our system, remove them.  A firewire device will reserve bandwidth for itself even when it is not in use.
The majority of Firewire implementations use a single controller for multiple ports meaning that the bandwidth is shared.  Simply unplugging the extra devices may solve your problem.  The other solution is to install either a second Firewire controller or search for a provider of Firewire cards with a dedicated controller per port (these are quite rare).
Shane.
(5,441 Views)
