Machine Vision
Integrate external trigger into the camera (PCI 1424)
hi every1 I am using a pci camera,and there are around 3 sofwares using camera,wen i switch 1st one(software) on it gives proper o/p,2nd one also is proper o/p but after 2nd one when i start 1st one again it gives error somehoe it fais to again initialise the camera
wat shud i di
thnk u
Message 11 of 12
(1,109 Views)
Hi ronnie996,
Can you post your codes? Maybe if you describe your hardware setup and software setup it would be easier for us to help you further.
Sincerely,
Krisna Wisnu
Certified LabVIEW Developer (CLD)
Certified TestStand Developer (CTD)
Using LabVIEW 8.5.1 (2008) to LabVIEW 2024
Message 12 of 12
(1,074 Views)
