Machine Vision
Integrating dataray wincam
Hello Anna,
Please email support@dataray.com with your contact information and someone will help you out.
Rocco
Message 11 of 15
(1,318 Views)
Hi Anna,
Since this is a pretty old forum thread, you might get more responses by creating a new thread specific to your situation.
Also, could you clarify your question. Are you looking to switch from one data ray camera to another or trying to build a new system from scratch? Ultimately, you might get more specific information by contacting data ray support directly.
EDIT: Looks like Data Ray got here first. Best of luck Anna!
Message 12 of 15
(1,314 Views)
Thanks Rocco and Will K!
I am creating a LabVIEW program to acquire CCD images from four data ray camera's and display the calculated parameters.
I am taking the help of data ray support team and they are quick in response.
Message 13 of 15
(1,306 Views)
Hi, I have successfully made it work before. Like in 2013. And it is still working on production line. You just need to use the ActiveX Panel and locate the OCX file and link it. They have some documentation on what nodes to access.
You need to start the dataray application first, to initialize then use your LabVIEW.
Message 14 of 15
(1,302 Views)
Good to hear. They work great with two cameras. Four cameras are slow though.
How many cameras did you use and the image update rate?
Thanks in advance!
Message 15 of 15
(1,298 Views)
