Machine Vision
Introduction to IMAQ Count Objects 2
Hi Guys,
My LabView connection and the front panel is as such. My Software is designed in a way whereby it will auto detect any cells that fulfill the size requirement of 3000 - 100000.
During this process, a region of interest is created around the the cells and at the same time a ID number is assigned to it. However, whenever i move the joystick which moves the area of interest around, the position of the cells changes and new cells might appear and disappear due to the limitation coverage provided by the camera itself. As a result, the ID number changes (even though it is the same cell) as the programme works in a way which it will always start assigning the number from a top-down and left to right approach.  I was wondering is there any way i could permantly assigned the ID number to every specific cells without changes everyime i move the cover-slip (Glass use to store the cells)? Probably based on the size of the cells or any other unique specifications i could rely on to make a permanent ID number to it.
Thank you in advance.
Best Regards,
Scott
(5,106 Views)
Duplicate discussion. Please keep it all in one place.
(5,098 Views)
