Machine Vision
Iron palette
When I use Vision Builder A.I. then I can select "Iron palette" in the Options"Image dispaly"
but, when I use LabVIEW with Imaq vision 8.6, then I can't select "Iron palette" in the LabVIEW.
Only I can choose 5 types of palette.
so, Could anyone tell me how to select "Iron" palette in the LabVIEW?
and If doesn't it then could you advice to me how to set up the cluster values of Color pallete?
Please advice it to me
Jun
(3,554 Views)
hi redfield,
you are right. labview have only 5 types of display palette. but i dint get any other information regarding IRON palette.
Alpesh Prajapati
(3,547 Views)
