Machine Vision
Is EVS IEEE-1588 capable?
I've been working with a NI PXI chassis with a 6682 card that syncs to the IEEE-1588 Master clock in a Rockwell Automation PLC over ethernet.  Can an NI Embedded Vision System (EVS) perform the IEEE-1588 synchronization?  If not now, is there a plan to develop this capability?
(3,130 Views)
There is no explicit hardware support for 1588 on the EVS, but the NI-TimeSync plugin with software 1588 support should work. I believe you can expect sub-millisecond performance with the software-based solution on RT systems. See this page ( http://joule.ni.com/nidu/cds/view/p/id/2520/lang/en ) for details.
Eric
(3,127 Views)
Thanks Eric, I'll give it a try.
Jeff
(3,122 Views)
