Machine Vision
Is IMAQ 2.6 fully compatible with Labview 6i?
Hello...does anybody knows if NI IMAQ is fully compatible with ALbview 6i?
What i´m trying to do is to convert a bmp or jpg image to a 2d array..i can do this with the vi ColorImageToArray but how can i get an array for each color plane without using IMAQ Vision module?
Is there a way to convert the 2D 32 bits array that gives the ColorImageToArray into three different color planes or arrays?..is it possible to do this without Vision?
thanks
thanks
(3,027 Views)
NI-IMAQ version 2.6 is fully compatible with LabVIEW 6.x. NI-IMAQ driver is an image acquisition driver and it has all the functionality required for acquiring images from an external video source through National Instruments frame grabbers.
In order to do image processing, such as performing operations on saved images from the hard drive, you will need IMAQ Vision image processing libraries.
Hope this helps!
Yusuf C.
Applications Engineering
(3,027 Views)
