Machine Vision
Is NIVBAITestStandAPI.dll compatible with Windows 7
Is NIVBAITestStandAPI.dll compatible with Windows 7 64 bit OSregsvr32 error.png
(4,988 Views)
Hello Big_Papa_Craig,
Did you followed some procedure like the one mentioned in section 1 of this following article?
"unning a Vision Builder AI Inspection from TestStand"
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LlySAE&l=en-US
If you are using TestStand 3.1 or later, complete the following steps:
  1. Copy inspection.ico to <TestStand X.X>\Components\User\Icons, where <TestStand X.X> is the location where TestStand is installed and X.X is the version of TestStand you are using.
  2. Copy NIVBAITestStandSteps.ini to <TestStand X.X>\Components\User\TypePalettes.
  3. Windows XP—Copy NIVBAITestStandAPI.dll to <Windows>\System32.
    Windows 2000\NT—Copy NIVBAITestStandAPI.dll to <Winnt>\System32.
  4. Select Start»Run to open the Run dialog box
  5. Enter regsvr32 NIVBAITestStandAPI.dll in the Open control and click OK. A dialog box should appear that readsDLRegisterServer in NIVBAITestStandAPI.dll succeeded.
  6. Click OK to close the regsvr32 dialog box.
Is the error you're showing, the result from step 5?
Regards!
>>Daniel
(4,978 Views)
Accepted by topic author Big_Papa_Craig
Hello Danubio,
           I did follow that procure you listed and it is not deteled enough for Windows 7. I figure out and sent my steps back to NI to update "Running Vision Builder in TestStand' tutorial. Below are the step I followed.
  • Using TestStand 2014 32 bit version
  1. 32 bit version TestStand Path =C:\Program Files (x86)\National Instruments\TestStand 2014.
  2. Copy inspection.ico to C:\Program Files (x86)\National Instruments\TestStand 2014\Components.
  3. Copy NIVBAITestStandSteps.ini to C:\Program Files (x86)\National Instruments\TestStand 2014\Components\TypePalettes.
  4. Copy NIVBAITestStandAPI.dll to C:\Windows\SysWOW64.
  5. In Start menu 64 bit version of CMD must be open as Administrator (Path = %windir%\SysWoW64\cmd.exe), CMD icon will appear in top of search window, Right click and “Open As Administrator”, enter Regsrv32 NIVBAITestStandAPI.dll, and Enter key. A dialog box should appear that reads DLRegisterServer in NIVBAITestStandAPI.dll succeeded.
  • Using TestStand 2014 64 bit version
  1. 32 bit version TestStand Path = C:\Program Files\National Instruments\TestStand 2014
  2. Copy inspection.ico to C:\Program Files\National Instruments\TestStand 2014\Components\Icons.
  3. Copy NIVBAITestStandSteps.ini to C:\Program Files\National Instruments\TestStand 2014\Components\TypePalettes.
(4,973 Views)
