Machine Vision
Is VDM .NET support native?..is it faster than VC++ ?
Hi all,
I would like to know if Vision Development Module' .NET support is native or does it use wrapper objects to COM technlogy?
If the same vision functions are used with VC++,  will they perform better than .NET ?
Thanks to all for your support!
(4,569 Views)
satriani81 -
The Vision Development Module's current .NET support is an interop layer around a COM object.  Due to the COM overhead, using the C or LabVIEW API should be somewhat faster, although I haven't done a direct comparison to see if it's a big difference or not.
Greg Stoll
Vision R&D
Greg Stoll
LabVIEW R&D
(4,566 Views)
I'm able to develop in VB .NET, not in C++, can you provide some samples to do a comparison?...for example a program that loops "n" times and counts elapsed time
I think it's a good thing to show users pros and cons of a programming language with your Vision Development Module.
What's the development road map of Vision Development Module?...do you think to improve performances with native .NET support?
Thaks for your care
(4,555 Views)
I spent the last two days in making some tests: I built a vb .net sw and a C console application, both performing the same task, a convolution of a 1280x1024 image with a 7x7 kernel.
I measured with a high resolution timer the time spent by cwimaqvision.convolute and imaqConvolve: 32ms in C and 180ms in VB .NET !!!
At this point I built a dll in unmanaged C++ inmplementing in it the imaqConvolve function: I call this dll with pInvoke from vb .NET and the performance is quite the same of C console application. For time consuming tasks I think that the dll way is good but there is a little problem that I hope National Instruments developers can help me to solve: actually I have to convert the CWIMAQIMAGE type in  IMAGE* type and then from IMAGE* to CWIMAQIMAGE.....to do that I used cwimaqimage.imagetoarray in vb.net and imaqArrayToImage in dll.....ARGGGGGGG....the array format is not compatible between .net activex and c !!!!! I noted that in .net the bidimensional array is saved in memory as a columns array, in C the array is created as a rows array...so is necessary to organize memory with a for cycle. Too much overhead.
Is it possible to have in C a imaqArrayToImage compatible function with .net array format ?
Do you have other suggestions ?
Thanks all
(4,533 Views)
satriani81 -
Are you sure you're timing the right thing?  I just did a quick example, convoluting the same 1280x1024 image with a 7x7 smoothing kernel in C and VB.NET, and in both cases the times were consistently in the 39-40ms range.  I definitely wouldn't expect .NET to take anywhere close to 6 times as long!
If you keep getting this result, attach your VB.NET project and code, as well as the image you used and I can take a look.  Calling directly into the C DLL from .NET is certainly possible but pretty painful, and I don't think it should be necessary in this case.
Greg Stoll
Vision R&D
Greg Stoll
LabVIEW R&D
(4,468 Views)
Hello Greg,
you'r right, I used the convolve method passing to it the optional parameter mask image....it was the cause of slowing.
Without a mask image, timings in .NET are quite the same of C, but I noted that in .NET the execution time is more variable: more frequently you call the convolute method and more constant is the execution time (ex if I call the convolute method once a second timings vary between 35ms and 90ms, if I put the convolute in a loop, timings are 35ms fixed)....why that?
Please, another question for you: if I want to use two threads to convolute images from two indipendent cameras, can I execute this method in parallel?.....is convolute method reentrant?
Thanks a lot for your care!
(4,459 Views)
